Marker attributes
Marker attributes apply to the pen style of an object. You can apply line startpoint markers and line endpoint markers to open objects, including lines, arcs, polylines, 2D polygons, and freehand lines. You can also apply line end markers to the leader lines on callout and dimension objects. Dimensions have other default markers assigned as part of the dimension standard setup, but these cannot be applied or removed through the Attributes palette.
From the Attributes palette, click Line Startpoint StyleLine Endpoint Style, or both to specify the end(s) to receive the displayed marker. To always use the same style for both ends of the object, also click the Marker Link Toggle button; whenever the marker style of one end is changed, the other end’s marker style automatically changes to match.
To create a new marker style or to edit an existing style in the marker list, click Edit Marker List; see Editing the marker list for more information.
To set a custom marker for a selected object without changing the marker list, click Custom. The Edit Marker dialog box opens; see step 2 in Editing the marker list.
Select Class Style to use the marker attributes set by the object’s class (See Setting class attributes). If Use at Creation is enabled for the object’s class, the object’s marker style is automatically set by the class.
Command
Path
Edit Marker List
Tools > Options
You can customize the set of markers available from the Line Startpoint Style and Line Endpoint Style settings on the Attributes palette. The edited markers are saved with your user preferences, so they are available from one Vectorworks session to the next.
To edit the marker list:
Select the command. The Edit Marker List dialog box opens; edit the list.
Alternatively, select Edit Marker List in the marker list in the Attributes palette.
Parameter
Description
Current Marker Types
Lists the marker types that are available for selection when drawing; change the list order by clicking and dragging in the # column
New
Creates a new marker type
Edit
Edits the currently selected marker type
Delete
Deletes the currently selected marker type
From the Edit Marker List dialog box, click New to create a new marker type, or click Edit to change the currently selected marker type.
The Edit Marker dialog box opens.
Parameter
Description
Preview
Displays a preview of the marker’s appearance
General Options
Specifies the marker’s shape and style
Root Type
Specifies the general shape of the marker
Fill
For closed root types, specifies the type of fill
Base
For triangular root types, specifies the shape of the base
Angle
For triangular and hexagonal root types, indicates the angle of the root
Length
Indicates the length of the marker, from base to tip
Width
Specifies the marker width, for marker types that have a width
Half Tick
For marker types except cone and lasso, displays half the marker on the indicated side
Tail
For markers which can be reversed, flips the marker direction to create a tail marker
Thickness Options
Specifies the marker pen thickness
Use Line Thickness
Uses the same thickness as that of the associated line, adjusting automatically along with any line thickness changes
Use Dimension Slash Thickness
Uses the same thickness as the dimension slash, set on the Dimensions tab of the document preferences (see Document preferences: Dimensions tab)
Use Custom Thickness
Specifies a custom marker thickness and unit (mils, points, or millimeters)
The new marker is listed at the top of the marker types list.
Alternatively, click Delete to delete the selected marker from the list.
The Attributes palette
